INSP | SatelliteGuys.US
INSP
Diamond Jim
4,393
525
The Boilermaker State (#19)
I have read where INSP has gone digital on G15(G1) TP 150 or 600.
When I go to G1-600 it tells me searching for channel, but nothing happens. On G1-150 it tells me this channel not available. This is an older 922 that was given to me after mine went south. I assume that it has been updated because I have X4 and I get the DMX channels on TP 900 to 940. What do I have to do to get INSP?
I am assuming that I can not get it on the Traxis 3500, the Quali TV or the AZ Box Premium Plus.
Diamond Jim,
if you have the old map it was on G1 600 but sometimes on mine i have to let it set there for a minute or so and it will pop in. I remapped mine with the mapmaster program and the channel for INSPN ch. 950 but it has to set a minute to come in. I dont think the 920 will pick it up.
Jim,I'm getting it ok @G1-600 with a 922 and 12'Paraclipse.But it's not as strong as the hbo's.Quality on 600=70,Q on 101(hbo)=74,Q on 171(starz)=99.Plus the lnb has to tune over +3 off frequency (why it takes awhile to lock) to get it,the others are about +1.5.You might have to do a little tweaking on your 8' to get it,but it is there.
RFD TV
Tweaking this dish is defying the odds!
