Not when it's properly aligned. It may go out in a downpour but not just a rainstorm.I can't believe they deploy those wimpy little dishes even on commercial buildings serving many customers. Bet all the guests will be thrilled when they lose TV every time it rains.
Looks great, nice install. What company did you hire to do it?![]()
How many rooms/TVs is this set up for and what receiver model is in each of the room/TV? The RV resort I live in has a Directv setup, but it is only SD. I am curious as to what will have to be redone to make each site able to get HD? The receivers for this setup is in the control room and the feed is then sent out to each site
The Technicolor box must be where the magic happens - does that act as the DirecTV receivers and then send an ATSC signal to the TVs allowing the rooms to just use the tuner built into the TV?
With 3 modules in that thing that would be 18 channels per, or 9 channels per incoming coax, something like that?
Crazy the level of items it takes to make that work, such as the SWMs and all the power inserters. They have larger setups for commercial, but I'm guessing this is more cost effective.
Was that the only spot you could get a LOS, in the middle of the roof?
100 rooms, HD over coax using encryption.
54 channels
Sounds like a odd way to go about it and to wind up with less channels?
Every time I've stayed in a hotel with DirecTV they had a commercial H25 hidden behind the TV...
Just a guess, but with 100 rooms at $100 a piece for a commercial H25 (if not more since they are full purchase for commercial), you're looking at $10k in just receivers. I have no idea what that COM unit Claude used costs, but there is a good chance it is less than $10k (or at least comparable). Also less maintenance, if one receiver goes bad, sending someone to replace it is not cost effective. Having them all in the one unit, which likely has remote configuration, can reduce service costs as well. Lastly, easier install, especially if the rooms are already wired with TV to the wall jack, such as if they used an in house cable head-end previously.
Now I'm curious to see what Claude says really is the logic.
Limited time offer
