installing a 6 foot dish | SatelliteGuys.US
dj_flako
102
pa
what is the minimum distance a tree can be on front of the dish
and a garage and how hight should i put the dish in other words how tall should the pole be
Well my neighbors planted trees in their back yard, now my dish is 14' off of the ground:mad: But I put it next to the house so I climb on the roof, swing the dish around and work on it.
Terry
It depends on your location, the satellite(s) you're trying to receive, and the height of the tree(s) in question.
I have a 20' tree that is about 15' or so in front of my 10' and 4' dishes, but since my lattitude is around 30 degrees and the tree is due south it doesn't really interfere with my reception. The 10' dish is about 8 feet off the ground and my 4' is about 6 feet off the ground.
You can try using dish pointer...it has a tool that allows you to judge whether an obsticle's height will pose a problem.
Good advice, what I did to decide how high to go with my dish was got a cheep angle finder, found the angle for the sats at my location then used the angle finder to sight off of, added more space for future growth and put in the dish.
Terry
Need MTI 2800A info
Oscillation Fixes/Cures?
