Simon, thanks for the info and please excuse my ignorance...soooo would I go two satellites into each DP21 and the DP21's into the DP34? Or ? BTW I am going to mothball my 7200, so I'll just be using my 921 and 510. Thanks again!
I have a good imagination, but I can't imagine this.SimpleSimon said:You'll need a DPP44 switch or a pair of DP21s (much cheaper).
You'll need to pull the DPP-Twin from the D1000 and use you existing standard DP-Twin in it's place.
Precisely - the 510 doesn't need 129.havana said:Thanks gentlemen...I am now only slightly more confused instead of totally confused...one thing I just thought of is that I really wouldn't need the signal from 129 going to my 510 since it wouldn't see the HD channels anyway right??? I already get all the programing from 110, 119 and 148 I want on the 510...the only reason I would like to add 129 is to get the Voom channels on the 921.
Limited time offer
