dave7424 said:You need to read the beginning of the thread. Larry's getting touchy on the topic.![]()
dave7424 said:Simple and should work.
dave7424 said:My question pertains to a situation that would arise if I were to add a 921 or 942 in the future and drop say the 4900. It seems that I would have to replace the single lnb with dual looking at 61.5. It would also seem reasonable to use a multiswitch, or potentially upgrade to dishpro products. The 942 would need 2 feeds with the 61.5 and the 811 would need to see the 61.5. I would also need a total of 5 sat feeds, 2 for the 921, 1 ea for the 811, 501, and 301. Any ideas on a set up ?
larrystotler said:I guess one of us is going to have to post an instruction manual for using a D500 on the 61.5(against my recommendations), and how to hack the V* and D* dishes to use the DP LNBs.
SimpleSimon said:Yeah - you've done a good job, but I disagree with your saying modifications to D* or V* dishes aren't worth the effort. I think it's gonna be pretty easy (10 minutes) - as soon as we know the correct measurement.
I've got a thread going over on Claude's board.
The H said:I've read all this thread, but I'm still a little confused about which way to go.
Right now I have 1 Dish 500 dish with a DP Quad LNBF,
- 1 Dish 500 dish
- 2 DP Twin LNBFs
- 1 DP34 switch
What I want is the ability to have 3 sats (110, 119 and 61.5) feeding a 311 (kid's room), a 811 and a 942 (or any other future HD-DVR that I decide to get from E*).
Can I use that Dish 500 + a DP twin LNBF to get it? or should I try to use Voom's dish + a legacy dual LNBF?
larrystotler said:If you use the DP Twin, you will need the DP21. This can work, but it can create problems. Make sure that you seal the ports hanging off the dish with silicone to protect them. Also, cover the unused side with aluminum foil to tune in the dish. I would not try this with a legacy system. Good luck.
rrolsbe said:The reason I would like to use a DishPro Twin is price. Dish 500 dish, then using only one side of the twin LNBF DishPro for 61.5 should not be, correct; however, I currently own a 18in Dishnet dish and would like to use the less expensive DishPro twin on this Dish 300 pizza pan.
The H said:One final question, though... what should I do with my V* dish? I had the crazy idea of using it (after doing a few mods to its bracket, of course) as my main dish since it is a 24" one instead of the old one, which has the same size of the Dish 500 one. Why use it? I was thinking that it could improve my signal reception quite bit and pretty much erradicate all rain fade problems from my setup. Do you think it is worth it or not? if not, what should I do with it? is it useful for other services (so maybe I could sell it on eBay) or should I just put it in my storage/throw it away?
Limited time offer
