But if its uses have been reduced to remotely monitoring the temperature of a fish tank (or a music player), is it really meeting "needs"?If it continues to function and fulfill a users needs then it ain't broke, no matter how old it is.
I installed iOS 11 on my iPhone. I do like the new Control Center, other than that no really big things stick out at me other than some things are different. It won't run 32 bit apps anymore. Other than that everything I have tried to use works without issue.
I installed WatchOS 4 on my 1st Gen Apple Watch, and I haven't noticed any changes there, there is no automated watch face as was shown nor are there the Toy Story Watch Faces shown off.
If it ain't broke means just what it says, it's not ambiquous. If it continues to function and fulfill a users needs then it ain't broke, no matter how old it is.
When the cost of a sensor that works with an iPad is much more expensive than a dedicated solution that includes an alarm feature that the iPad solution doesn't provide, that goes a much different direction than meeting a need. The real "need" appears to be to justify the keeping of the iPad around and that's silly.Then I would say that if the user only needs it to remotely monitor the temperature of a fish tank then yes, it is really meeting "needs".
Maybe the user just wants to browse the internet and his current device meets that need. Maybe the user wants to just use facebook and the app currently works so that current device meets that need. Or maybe the user justs wants something to hold his papers down on his desk and his current device meets that need.When the cost of a sensor that works with an iPad is much more expensive than a dedicated solution that includes an alarm feature that the iPad solution doesn't provide, that goes a much different direction than meeting a need. The real "need" appears to be to justify the keeping of the iPad around and that's silly.
Of course they do. There are internal people at Apple running iOS 12 on their devices right now, rest assured of that.The top tier test sites got the complete software that was also the buggiest. My level got the beta version that had already been vetted by the inner circle guys. I wonder if Apple works the same way.
This is typical when companies move to annual releases. There's no more "wow" really possible year after year.I was underwhelmed
Years ago, I was involved in beta testing some 3D-modeling CAD software (Autodesk Inventor).
It is a lot easier than it used to be. Back when, you had to use iTunes to move it to your computer.Now I want to copy that file to my computer for use in editing. It took me several hours of research to understand how to do that.
I don't think you'll find any app that supports XMODEM protocol on either side of the USB cable. FTP (today's equivalent XMODEM in a ZMODEM world) is kinda bare metal but it is a step up from the process of finding a suitable app that you've identified.You would think I could just connect the ipad to the USB port and copy and paste to File manager in Windows. Heck, I was doing basic file transfers back with my Radio Shack computer in the late 70's.
I can only imagine the terror that is sure to come from HEIF employing a four character filename extension. Windows weenies are highly dependent on this silly convention.
More recent ? You've been able to hide them (easily) all the way back to Windows 95, although I don't remember when they were made hidden by default.I think there is a little concern when more recent windows versions began hiding the file extensions by default. I turned them back on as I need to see that in my work.
Its a big deal since Windows can't figure out what the content of a file is without the appropriate extension and too many assume that three is good enough. The other side of the coin is that lusers used to change the file extension in order to force the file to be loaded in a different application or to try to get the file to load on a less capable device (often media players). This was a real problem with certain video container formats being renamed to MPG or AVI when they were actually FLV or MKV.Really? Maybe I don't understand your FUD, but we've been using 4 character file extensions for quite some time with media files. m2ts, adts, mp4v, 3gpp, to name a few. No big deal????
Do you include Windows 95 among the "recent" perversions of Windows? IIRC that's where the system started with known extensions being hidden by default. Of course Windows doesn't hide file extensions that it doesn't recognize but once you associate a type with an extension, it will happily hide those extension until you disable the default (just as the Mac does).I think there is a little concern when more recent windows versions began hiding the file extensions by default. I turned them back on as I need to see that in my work.
Other platforms long ago proved that it doesn't have to be.But it shouldn't be this hard to share content between devices.
I don't think that is where Apple has been headed all these years. They're more of a "regular floggings will continue until morale improves" kind of camp. They very effectively use small but decided difficulties to get their disciples invested in the platforms in hopes that some day they will become Apple acolytes to preserve their considerable investments (in both learning the obscurities and substantial financial outlay)."Low Friction", I think I heard one tech pundit say, should be the goal.
Limited time offer
