IOS 8 Discussion | Page 9 | SatelliteGuys.US
IOS 8 Discussion
And here I am still on 6.something on my iPhone 4... I'm still leery about updating my phone since 7 will slow it down a lot, and (so far) all the apps I have still work fine in 6. I don't connect to any wifi other than my own, so security shouldn't be an issue...
Anyone else have a problem staying connected to wifi? Quite frequently i will find I am connected to LTE/3G instead of wifi. When this happens if I check the wifi settings I find that none of the dozen APs I usually see are showing and the only way I can get the wifi working is to reboot.
Any suggestions?
Any suggestions?
No wifi trouble here. Might try resetting Network Settings.
Any suggestions?
Have you tried to reset the network settings? I read someplace that helped with wifi issues. Settings ---> General ---> Reset ---> Reset Network Settings
I had a problem until I went to Privacy > Location Services > System Settings and turned off Wi-Fi Networking. Then I reset the WiFi Settings. This doesn't turn off Wi-Fi - it just blocks the device from using nearby Wi-Fi networks to assist GPS in determining your location faster. I figure there will be a fix in a future release.
OK thanks guys I'll try both of these.
EDIT: didn't help
