The battery life sucks but I am now use to it.
The iPhone is definitely smoother running, probably because it doesn't multitask, a bit of annoyance. Also, I miss the capability to edit Microsoft Office documents and save them (although you can always save the original emails they were attached to). But it adds HTML email, and the web browsing (if you have 3G or Wi-Fi) is unsurpassed.
Adding Microsoft Exchange gives you push email, like the Windows Mobile phones, if you have an Exchange server. And the screen is MUCH brighter outdoors than any WM6 phone I've ever seen.
So it's not just the touch screen that makes the iPhone stand out. Not that it's perfect. But I vastly prefer it to the WM6 phones I've had (HTC 6800).
I had the 6800 and now have the 3G and I love it.
On the 6800 (while I loved it) I was always trying to make it look and act like an iPhone. Now I just have an iPhone and it works.
Only thing I am missing from my 6800 is the Slingplayer software.
Curious- can you play wmv video with the new 3g phones?
Video Specs:
Video formats supported: H.264 video, up to 1.5 Mbps, 640 by 480 pixels, 30 frames per second, Low-Complexity version of the H.264 Baseline Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; H.264 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Baseline Profile up to Level 3.0 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats
Apple - iPhone - Technical Specifications
Bottom line: If you want to carry your Windows PC -- for all its pluses and minuses -- in your pocket, get a WM phone. The iPhone goes in a totally different direction.
Yes, they need to address the battery issue; if you're in a 3G network area, you will lose battey power right quick. (Solution: Turn "Enable 3G" OFF in Settings until/unless you need it.)
Limited time offer
