IR to UHF Pro Converter Kit | SatelliteGuys.US
hzhao
280
I am installing IR to UHF remote converter kit to my 211K. According to the manual, for old 311 receiver, there is a special slot under the receiver to install the IR extender (rather then using the tape to stick it in front of the receiver. Is there a slot under 211K for the same purpose? it would make a much clean install.
Thanks in advance.
There is not a special spot on the bottom, but you can stick the emitter over the open slot on the bottom. The slot is the one almost parallel with the ir receiver (the one in the center). I put the emitter in parallel with the slot and ran the wire out the back. Works fine.
DISH vs. Comcast?
OTA Module with cable
