Is 1000.2 and dish 1000 the same thing? | SatelliteGuys.US
DallasNewbie
7
Retailer told me that the 1000.2 dish is all the dish i will need including all the hd stuff.
TRUE OR FALSE?????????
Not the same thing, but they both get 110, 119 and 129. The 1000.2 is slightly bigger and has a triple DPP lnb while the 1000 had a DPP Twin alongside a DP dual.
The 1000.2 is slightly better for signal strength. It will get you all the HD available, except for some locals on 61.5 which you probably aren't in the spotbeam for.
FALSE for FTA. Possibly TRUE for Dish Network subscriptions. That dish won't get you anything FTA other than NASA TV, Angel One and occasionally another channel or two for a few days.
You should really ask this over in the Dish Network forum as they can get into all the details about the 1000 versus 1000.2 versus 1000 plus, but if you're going to subscribe to Dish / Dish HD I would suggest getting the equipment from them as part of the install. They usually subsidize it quite a bit.
The Dish 1000 came out before the Dish 1000.2 did. Once they came out with the 1000.2 they discontinued the 1000. My guess is that the first dish that came out could also be called a 1000.1 to prevent any confusion (D1k.1 for short).
If a retailer is trying to sell you a Dish 1000 for FTA, that retailer is catoring to hackers. As Gillham said, that dish is next to useless for true FTA.
Galaxy 19 might have chanels on it
Coolsat in Convienience Store
