Is NASA TV still FTA Via The Dish Network | SatelliteGuys.US
kc5qih
SatelliteGuys Guru
144
Good Evening Everyone. I was wondering if I could still get NASA TV Fta on Dish Network 119; i know when i used to have dish network; even after i turned off the service i could still get NASA so i was wondering if it is FTA so i can get it now.
Thanks..Chris
You will still need a circular LNB or one of the newer dual linear/circular.
NASA TV / Echo 7=119W / TP=12297-L / SR=20000 / VPID=5922 APID=5923
NASA, Angel One, Dish Help and the audio (sans Sirius) are on 119
Check the FAQ section "what can I get with an 18" dish" for everything you can get FREE with a DBS LNB :)
ah okay; so the universal that is on my fortec will not work; have to invest in another LNB..okay well that answers my question.
Thanks Everyone.
hmmm. I do have an old 18" Direct TV dish just lying around. Perhaps I can dig it out and put it up aimed at 119 and it is roll that way. Guess I'd have to get a switch to run between my two dishes then.
Chris
that would work also. Or you could put it next to the KU band LNB :)
you would need a DiseQc switch (2x1 or 4x1)
Pantech 2500?? anygood
Pansat 3500 Vs ViewSat VS2000
