Issue with abc in okc | SatelliteGuys.US
chrisd_az
159
8
Chickasha, OK
Since I have had D for a month now my local abc stations volume has been low. I have to turn my tv up to 60 just to hear the ou game tonight or shows. I know it's not the tv cause I change the station an it's freaking loud have to turn it down. Just wondering if anyone else out here in okc with the same prob.... Thanks chris
I have a similar issue with KSN in Wichita, but it only happens on certain shows, namely newscasts. Then they have the 'commercial blast' because they don't normalize the commercial volume. I have called their engineering department a couple times over the past year and I keep getting told "We'll look into it". If it's the entire channel all the time though, it might be worth calling D* on because it could be at their end.
I would contact the engineer at the station in question. They can work with D* faster than if you called and spoke with D* CSR's or even tech support
reddng chico dma locals keep freezing
Why does this happen and who to bitch at?
