Joey works but black screen on Hopper | SatelliteGuys.US
Bill L
7
Texas
I have an issue with my set up. My Hopper TV has a black screen except when the Hopper is starting. If you go to the Joey TV, all works well including watching DVR recordings.
I have gone through all the resets, unplugging etc.
Any suggestions?
Thanks for any help.
Any suggestions?
How do you have your Hopper connected to your TV? Have you tried using a different cable?
Yes it is connected to the TV. I don't think it is the cable because if you turn the Hopper off, the little help tip/screen saver comes on. This indicates that the Hopper can reach the TV. If you toggle the power on the Hopper, it's start up sequence shows up on the TV then goes black.
Finally found someone with Dish that knew their stuff. While the remote would work, they suggested pushing the "power" button on the Hopper. This solved the problem. They said it was software related.
Move from western arc to eastern arc
