Just a little more help with setup for motor and lnb | SatelliteGuys.US
ussexplroer
272
4
Getting there with FTA
So I went out this morning and looked at my post. Noticed it was not longer sticking straigt up. This was on the side of my house. So I'm like yea. SHould have attached the extra braces. So now they are on. I can go back and finish turning the dish and motor.
laters,
Josh
Remember that especially with a motorized system, it is VERY important to be sure the pole is exactly level for the dish to track the arc properly. If you are installing a motor, factor in the motor weight when checking the pole for plumbness, it will pull the pole slightly.
Serious Inquiry for Quali-TV QS1080IR(CI)
Sats with temporary channels ?
