so far... my SD dvr recordings transfered without a problem... my mp3's are working... more as I investigate more....
Scott Greczkowski said:All MP3's are working for me now, I am guessing they did some kind of software update which was transfered to the pocketDish when I synced it with my 942.
The only ones it wont play are the ones I purchased from ITunes.![]()
Sean Mota said:Here's a way to record the digital OTA channels. I have an ATI wonder card. I get all the locals through the card. If you record those chanels in Home Theater format (mpeg-4), you will be able to transfer the file to the pocketdish and it will play on the pocketdish. If for some reason you also want to record the HD signal, you can do the same with mpeg-4 format which downgrades the HD signal. I think this solution is better than real-live because you can record to the pc and then grab the file and transfer to pocketdish.
Limited time offer
