Just ordered HR24 | Page 7 | SatelliteGuys.US
Just ordered HR24
Well, here ya go. This box will def sit on top of the AM21, not under.
Haha. Prob be Sat or Sun, whenever we can get the bedroom one cleaned off so i can set up the 24 to take over recording duties. Living room dvr wont be cleaned for the swap for a good 4-5 days.
Ok, tell you what. Call and activate it, and ill come pick it up to test it out for you until sat or sunday. You know, just to make sure it works ok:tux:
B-band
Hi ,since i now have the HR24 and two HR22 and i hooked up b-bands on the HR24 in order to make it work. If i had D come out and hook up the SWM will that make the HR24 any better or just the same and can you take the B-BANDS off the HR22.
No HD reception
30 Second Skip
