Only have 4 GB in my 27", but I haven't had problems with running short of RAM.
Neither have I but 8GB additional for $47, just can't pass it up.
Alas, when you buy that $40 ram, and install it yourself, you void the warranty![]()
Chances are that they are a different DRAM type. DRAM doesn't like to be mixed.mperdue said:Edit: It seems the two modules both work separately but won't work together. I guess I'll be using that RMA number...
I still have to run a couple of Windows programs as well but Parallels makes it pretty painless.
I don't have an ergonomic keyboard, but I have a Macally USB keyboard that is decent. They have a bluetooth one too. I also have an OS9 G5 keyboard that has great tactile feel. I can't stand the current Mac keyboards. There are a few ergonomic keyboards designed for mac See: Amazon.com: mac ergonomic keyboard
Are you getting a magic trackpad for your setup? I would not use a mac without one. I have one at home and one in the office. The magic mouse I can take or leave, but the trackpad is essential.
The only downside is Parallels adds Windows icons FOR EVERY SINGLE Windows app in the VM, and OSX then includes every one of them in the launch pad. Took me a while to clean it all out. I just did not want most of them cluttering my nice display. If I were to do a new VM, I would strip that thing down from the beginning and basically not install 90% of the windows apps.
If you change your VM mode to full screen or window, then this problem doesn't exist.
Limited time offer
