SOLD!! - Kitz Technologies KT-200 Super Low Noise Pre-Amp Coax Powered | SatelliteGuys.US
SOLD!! Kitz Technologies KT-200 Super Low Noise Pre-Amp Coax Powered
Not open for further replies.
cpalmer2k
1,079
677
United States
This model was used for a single test using an "omni directional" antenna that didn't work for my location, so I just don't need it anymore. It has never been mounted or used outdoors in the weather and is in perfect shape.
Asking $70 including shipping!
The KT-200 is a fixed gain (24db) TV amplifier with an ultra low noise figure of .4db. The KT-200 is a good choice for medium to very long distance TV reception. This amplifier was designed to help with those weak hard to get channels. Our goal, when designing this amplifier, was to have the lowest possible noise figure. It is designed for use in rural areas without strong transmitters near by. The KT-200 also has a built in FM filter for improved VHF reception.
Kitztech TV Booster
KT-200 Specifications:
Bandwidth 54 Mhz - 806Mhz
Noise Figure: .4 db
Gain: 24 db
Built in FM Trap
Input/Output Impedance: 75 ohms
Fully Shielded Aluminum Case
Case Size: 3.125" x 2.125" x 1"
DC power supply included
Amplifier Power: 7-14 Volts DC @ 70MA
Warranty: 1 Year
