FOR SALE - Kitz Technology Low Noise KT-501-COAX Pre-Amplifer | SatelliteGuys.US
FOR SALE Kitz Technology Low Noise KT-501-COAX Pre-Amplifer
  • Thread starter Thread starter cpalmer2k
  • Start date Start date
  • Replies Replies 0
  • Views Views 894
cpalmer2k
1,079
677
United States
I'm selling some Kitz Technology Pre-Amplifiers I bought awhile back to test with my antenna setup. Both were used by me once or twice in testing, but have never been outdoors. These are the COAX powered versions with the waterproof aluminum housings. I ended up going with two Televes antennas pointed in opposite directions that have built in amplifiers, so I just don't need these.
Asking $70 SHIPPED for this one (retail is $80 with the coax power option). Will entertain offers though.
The KT-501 is a variable gain (0-17.5db) TV/FM amplifier with a low noise figure of .85db. The KT-501 is a good choice for close to long distance TV reception. It is also very good for FM reception. It is designed for use in any areas including those with strong transmitters near by. It is designed to be very overload resistant. The KT-501 is our best amplifier for FM where many strong local channels can cause bleed through to adjacent channels. The variable gain can be adjusted to eliminate the bleed through while still helping receive the weak channels.
Kitztech FM or TV Booster
KT-501 Specifications:
Bandwidth 54 Mhz - 806Mhz
Noise Figure: .85db
Variable Gain: 0-17.5 db
Overload Resistant
Input/Output Impedance: 75 ohms
Fully Shielded Aluminum Case
Case Size: 3.125" x 2.125" x 1"
DC power supply included
Amplifier Power: 7-14 Volts DC @ 70MA
Warranty: 1 Year
