I checked the info screen & it showed error on version line!! I had kept my 921 on during download & thus had not installed yet!
I did a smart card reboot. It installed correctly.
It installed software, then rebooted itself, then powered off to standby.
When I turned unit back on it was showing L187.
There needs to be guidance from Dish on the best, correct way to install software.
Does the software automatically install & reboot if unit receives it while in standby???? For L186, it seemed to do so. I still did a card reboot anyway. Was it necessary??
If unit being used, what is best way to install??
a. Place in standby & check in morning??
b. Do some form of manual reboot: smart card, power button, power cord
The 500 series actually gives a pop-up message about new software available & asks if we want to intall it now. This seems the best consumer friendly way. Whay does the 921 not do this???? What is the non-techie 921 owner supposed to do??
