cpdretired said:You can't even record a channel and view another live. The receiver has been used in the single mode.
Well i was doing that just fine tonight with 3.59 - so must be limited again to a specific type of 622 version.
cpdretired said:By reading previous posts Dish really screwed up this time. My receiver worked perfect until L359 arrived last night. As others stated once you hit the swap button the receiver crashes. With L359 the receiver is not capable of recording more that one channel. You can't even record a channel and view another live. The receiver has been used in the single mode.
Scott Greczkowski said:I am now watching ECW on the SCI FI Channel and the picture on my 622 is stuttering and almost looks like its in slow motion.
I have not reset my unit because it is also recording something for my wife.
cpdretired said:...As others stated once you hit the swap button the receiver crashes...
I have this exact problem as well.bobl said:L3.59 seems to have broken something for me! Every time I now hit the swap button, whether the PIP window is open or not, the receiver reboots. This never happened until today. Is anyone else experiencing this problem? I called Dish and they opened a case for this issue.
That was it. Thanks!Dirtydan said:For that "Swap Button" problem, go to System Settings and make sure Shared View is enabled
SummitCinema said:Ditto, happened to me tonight during the Mavs - Heat game.
philhu said:Don't they have a regression script to test EVERYTHING whenever a new firmware release comes out???
cpdretired said:I just got off the phone with Dish executive offices. They are aware of the 622 PIP swap crash problem. They are writing new software code to fix the problem. This can be fixed at the user end. When in the single mode select menu 6-2 and put the unit into the shared mode.
Limited time offer
