Jim S., Your right about the sat indicator on recorded shows, I went back a few months and the indicator was not shown, so I suspect it has always been this way.
Dan
Dan
Dan
I have a WD WDElements 750 GB ehd. It has been working fine since I bought it last November. My 622's got updated to L621 on 6/16/09. Now when I try to look at the contents of my WD drive it says "This feature is currently not supported".
The 622 recognizes when I connect and disconnect the drive, but the "My Media" folder does not show up under "My Recordings" anymore.
I have another drive, a Maxtor, that is still working fine.
Any ideas?
At some point in the past week, the problem of deleted programs not disappearing from a group until you exit the group spontaneously cleared itself up on my 622.
I just discovered the same problem with my WD EHD. I've had L621 since it was first sent out and was subsequently able to access the hard drive, but this morning I am getting the #863 "This feature is currently not supported" message. Rebooting the receiver and unplugging the EHD is no help.
Does anyone have a soultion short of calling tech?
Methinks there are a lot of folks without L621, like me (thankfully I'm still on L618).There must not be very many folks with the same problem that I'm having since there have been no responses to my question...
I'm still on L618 as well, even though I would like some of these updated features; but frankly, I suppose I will let you guys work out the bugsMethinks there are a lot of folks without L621, like me (thankfully I'm still on L618).
We're also having this problem. First step by tech support was to decide that the receiver had gone bad and send out a new one. I set up the new one (which had L618) and it saw the WD EHD but wanted to reformat it. I called tech support again to get them to fix that problem. The fix apparently was to download L621 which brought up the dreaded "This feature is currently not supported" mssg. The next tech put in a "technical report" and told me to call back in a couple of days. Today's tech "Sue" was very helpful. She says there is a known issue with WD EHD's that they are working on and a software fix is expected shortly. She told me to keep checking for the next software download and check the EHD when that arrived. So I guess we just wait.
The recording Options don't seem to work for me anymore with 621. If I try to record only New episodes, it records everything. If I tell it I only want to save the 4 most recent recordings and have it auto-delete older ones, it doesn't do that anymore either. I've got a program set to keep only the 4 most recent episodes and since yesterday it's recorded 17 episodes. Anyone else observed these problems? It's been this way for me since I got 621 several weeks ago. I can't believe Dish hasn't released an update yet.
Limited time offer
