I currently have an HR21 and an H21. After getting an HR22, can I exchange the HR21 for another H21 with no new leasing fee?
Yea wow I didn't see that eitherDid I read it right, you want to return your HR21 and get an H21?
Why - to not have DVR?
I think you should stick with what you have.
Y'all didn't catch the first part -- I'm getting an HR22. I want to replace my HR21 with an H21. Don't need 2 DVRs. And with them both being in the same closet, I don't want to have to deal with both DVRs recording something when I hit the record button. I know I can have one of them RF and the other IR (remote), but that would create more of a headache. Utilizing a matrix switch, I can watch the HR22 at any TV set anyway, so that's not an issue, either.Yea wow I didn't see that either
Are you sure you want to do that? D* doesn't charge anything extra to have that HR21 Vs H21.
Is there any way to disable the recording part of a DVR?
For scheduled stuff, that would do fine. But, when I hit the record button, both would record, which means that I would have to go through the list every so often and delete everything. PITA! But, if that's what has to happen, I guess that's what will have to happen...I would say simply delete everything in it's to do list and / or priory list it should not record.
That would have me using 2 remotes -- one for the DVR and one for the TV. I was hoping to avoid that. I was also hoping to avoid making my wife learn a different remote than what she's used to -- we don't use the D* remotes, but I suspect we may have to. Does anybody know if the Big Button remote can be programmed to operate a D* receiver via the AV1/AV2 switch like the regular remote can.If they are going to be in a closet, you probably want them both to use RF anyway. In that case the remote is programmed with the receiver ID and only controls one of them (AV1 could be used for the other).
[FONT="]Does the rf remote do rf ONLY for the receiver, and ir for the other functions (TV)?[/FONT]
Limited time offer
