With a Sling Adapter, yes.With a VIP722K? Are you sure?
Interesting. Does it work properly or is it prone to errors/freezing/slow load times?Yup. I can vouch for the fact that the Sling Adapter (of which I have one I'm no longer using) does indeed work with a 722 and Dish Anywhere with a FireTV Stick. I have purchased 5 sticks and they cost me $25/ea or less.![]()
Last time I purchased a used Dish Network receiver and activated it, Dish decided that they owned it and I was leasing it from them. I had to send them my purchase receipt to prove otherwise.
Needless to say, I left Dish Network forever after that,
I see. Thanks for the info.I had issues from time to time which seem to be gone with the H3. So I can't tell you how good/bad/reliable it is at pesent.
I use the fire stick (with a HWS) and no problems with freezing or loading.Interesting. Does it work properly or is it prone to errors/freezing/slow load times?
You should have insisted and stood your ground on a Hopper 3 right from the beginning.Well I upgraded, sort of. Since I was a "preferred customer" the sales(?) dept said I qualified for a free upgrade to a hopper w/sling and a joey. So I went against my better judgement and took the offer. Was promised that they would waive the 2 year commitment(i asked several times) and of course they didn't. I had to speak with several people to get it waived. Not happy about it but at least it was resolved.
Everything has been in place for a couple of weeks so I've had some time to play around with the hopper. Not very impressed. Too slow and cumbersome. Accessing the guide is pretty quick. But trying to navigate in and around things(dvr, menu, pulling up info) is a test of patience. I should have done my homework and avoided this thing.
If I could go back in time I would have kept my 722K and added a 211K. Much simpler and easier to use, especially for my 75 year old mother. It's not easy for her to make things work with this new user interface. Totally my fault for changing things up.
Since Dish won't let me lease/purchase/exchange a 722K from them I guess I'll have deal with it. Perhaps I can find one cheap on ebay or locally and reinstall it myself. I've heard I can purchase my own and add it to the account. Whether or not that is true I don't know?
But a 211k can.722 can NOT be on the same account as a Hopper.
Understood. I was thinking of dumping the hopper 2 and going back to the 722K/211K...but I wasn't sure if I can use them on a hybrid lnb. I found one example here that worked with a 722K.722 can NOT be on the same account as a Hopper.
What makes you think you have a hybrid LNB? That is not required for a HWS, just the Hopper 3s.Understood. I was thinking of dumping the hopper 2 and going back to the 722K/211K...but I wasn't sure if I can use them on a hybrid lnb. I found one example here that worked with a 722K.
Would I be able to use two VIP receivers on a hybrid lnb?
The installer put up a new Dish. So I figured he replaced it with a hybrid for the HWS. How can I check?What makes you think you have a hybrid LNB? That is not required for a HWS, just the Hopper 3s.
with your remote press: Menu, Menu (or Home, Home), DishThe installer put up a new Dish. So I figured he replaced it with a hybrid for the HWS. How can I check?
Limited time offer
