Legacy SW64 Feed Through Load LNB B Ports | SatelliteGuys.US
HDTVFanAtic
1,973
What exactly is a Feed through Load for the SW64 B Port if you run 2 SW64s?
If you split the feed off the lnb and the Blocked Port runs to the second SW64, why would you need a Feed Through Load?
And why are they only needed on the B Ports?
The way the SW64 was designed it has to have a certain load on the "B" port before it will be able to check for a signal on that numbered pair. Otherwise it acts as if that pair has no connection to a dish.
thanks.
so if you needed another one of these devices, where would one fine one? searching the usual sites turns up nothing?
Anyone use Pay as You go VoIP service for phone line?
Installing 322 on Legacy System
