lnb drift question | SatelliteGuys.US
lnb drift question
DishTechPA
262
SW PA
Hello, I have a 722k connected to a .4 ea. Since the sat 77 issue my system info shows lnb drift on 77. Is this bc of the anomaly or do I actually have an lnb problem. Thanks.
dish did have problems with 77 2 weeks ago, it would show a drift on 77 or something was blocking it. I did not notice them lately. Most of the times if you are not having problems with a drift, you either don't watch that channel with that particular drift or it is not being used
Strange... Does it effect your channels at all (signal loss messages or anything)? If the channels are working fine, I would go with the "if it's not broke, don't fix it" mentality.
No, it does not effect any channels. Being a tech I'm anal and check it almost once a week and it never appeared until the 77 issue. So I'm leaving it alone. I was just curious if anyone else on EA had the same issue.
Wireless USB Adapter deal
3 sat set up with legacy lnbs
