LNB LO for Orby | SatelliteGuys.US
LNB LO for Orby
lamp
74
28
Tennessee
Does Orby receiver work with universal LNB? Can you select different LNB frequencies with the Orby receiver? Does Orby recommend a certain LO frequency? I just ordered an Orby receiver and would be nice to know this before it arrives.
Thank you to anyone that can answer this question.
I used an old invacom quad connected to the linear side. Worked fine.
Sent from my SM-G955U using the SatelliteGuys app!
