LNB Problems? | SatelliteGuys.US
LNB Problems?
psc201
4
Hi,
I have an oval triple LNB unit - I have lost MSNBC, NGC and all of the Fox NFL Sunday ticket feeds in the 700 series satellites - everything else works great and Sunday Ticket works fine on HD - I'm getting signal strengths between 94 and 99 for 101, 110 and 119 and the systems check says everything is fine.
At NGC I get a choppy digital feed like when a thunderstorm approaches on the others I get a searching for satellite signal message
Any ideas?
Tom
BTW - I have 6 receivers (1 Hughes HDTV and 5 Samsungs) and have the same problem on all of them
On 101 transponder 21, 23 and 25 are getting no signal
On 119 transponder 29, 31, and 35 get no signals
all others seem fine most with signal readings in the 90's
Do I need to replace the LNBs?
Directivo without service
HDNet has PG info for Test Channel
