lnb | SatelliteGuys.US
lnb
jackpot
2
west michigan
new here, been with direct tv for 15 yr. i go camping, with my single lnb ,all spring i have no problem geting the signal, last week could not get it. my signal finder would read 65-70 for about 25-30 seconds then go to zero. im wondering if i have a bad lnb? is ther a test to find out if its bad? thanks.
Chances are you may have had obstructions or a bad connection.
Have you tried setting your system up at home since you've been back ?
If so and it worked, that would answer that !
Good luck and let us know.
btw, there is no test that I know of.
Jimbo
R22-200
Problem with HD Channels.......
