I'm not sure what happened !?
This is a copy from another Thread, questions which i ask, but, the Thread was closed. So...
I checked out the Invacom site, and copied info on some of the LNB's. I think I may have misunderstood some info I got in the past, and now I'm not sure that the SNH or TWH LNB's will do Circular, will they?
Is the key word "Polar", when it comes to the LNB's ability to receive Circular? I was just trying to select a LNB which didn't have any more "works" than needed, in looking at the Single and or Twin. I want to keep my system as compact as possible, which inadvertently will keep the cost down, that a MUST!
If I have to go with the QPH which has four outputs, what do you do with the extras? Just cap um off, and wait till you need um, if the first goes out, or what? I do understand it was made for 4 Receivers, presumably from a fixed Dish. But what value would that be, with a single Motorized Dish/Receiver?
And, from what I can tell, the Quad (OPH) is a lot more expensive than the Single (SNH) or Twin (TWH). I Must try to avoid any more cost than necessary, got to buy a Motor too.
Additionally, my dish says the F/D is .64, and the Invacom SNH-031 says it's a .6 F/D. In your opinion, is that within reason, an applicable substitution? Just how much "give" is there in the F/D. My Dish has about 2cm in/out adjustment with the Spitfire LNB, I suppose that's good, though I don't know if that will exist, if I use one of the Invacoms?
Also, I don't know what you meant by "ITC TV".
Iceberg,
Sorry, I only got Bailing Wire and Duct Tape, think that'll do? J It works on my old Pickup truck!
I wonder if "accidentally" is an appropriate term to use, when it comes to "them forgetting" to turn the encryption on. I've experienced some situations like that before, and I think it's more like "bate". They let you see all that wonderful stuff for a short while, and then cut it off, in hope you'll buy their plans. It's also possible, that the operators "play" with that stuff too, on and off occasionally, just to mess with us? I think that some Receivers scan automatically, and if a new Channel appears, it'll let you know, is that right?
As you may know, I have to write these replies off line, and post them the next day, because of my limited time online. I'm not sure what "DMSI" means, but I'll check the Glossary when I copy this post to the site.
Tron,
Thanks for the "legalities".
A general thought:
In looking at the signatures of some of the Members, I see where they have several Dishes, multiple Receivers, and no doubt all the switches and devices to "collect" that data for viewing.
It appears that I may run into some problems/expenses, in an attempt to "get it all" with just one Dish, Receiver, Motor and TV. I can understand adding/combining a C Dish into the system, or maybe duplexing a Ku/C LNBs on one Dish, but, just why would so many Dishes and Receivers be necessary, am I missing something here, am I trying to make that simple system do too much?
Of course it is possible that those things are "asexual", and just multiply on their own.
