looking for 180cm polar mount | SatelliteGuys.US
IntelPennny4
326
124
USA
im looking to buy a 180cm polar mount. i want to be able to use my 6 footer for KU but want to install it on a pipe and dont want to have it sitting on the ground anymore. if anyone knows or has one let me know thanks
Why polar-mount? Look for AJAK motor.... from time to time they still appear on the second-hand market.
I want to have a fix dish. Want to put it on a pipe. Idk what a ajak is. Don't want motor
Where are you located? I don't know about a polar mount, but I know where a complete 7 1/2 foot dish is that might be had. It's easy to get to as it's just off US33/48 in WV.
there is the pictures. live upstate new york near boarder
This one is not good for Ku-band. 1.2m solid antenna will perform better. Sorry to say so.
ok thanks. but i still want to install it on a pipe and getting it off the stand aka ground
Wait a minute, I do not understand something (probably cuz I am not native speaker)...... You wish to install this antenna on the mount (not necessary polar-mount) , just to be able to fix it to the vertical pipe and tune it to some satellite? Am I right?
maybe i am saying it all wrong but yes thats what i want to do. i did some research and thats what i came up with.
SADOUN SP180 Polar Mount
WS1870P
I see. This is good solution, but you will get polar-mount.... which you did not look for. Much easier and also cheaper to make mount like this, where you will have possibility to change antenna's azimuth and elevation. You only need to make it at the proper size. IMG_20170724_202033 (Large).jpg IMG_20170724_202039 (Large).jpg
I have one that was pretty much never used but its been sitting outside in my yard at a corner where I keep misc items.
Here is an image and if interested send me a PM
