Looking to get signal meter/finder | SatelliteGuys.US
I use an old Channel Master I picked up on fleabay for $80, had to replace the batteries and panel mount F connectors. It works great and it powers the lnb without a receiver.
Super Buddies are always great, but too pricy if this is just a hobby situation. You could try finding a used Sat Buddy. They are fairly inexpensive and very reliable. You could probably pick one up on craigslist.
Well, this meter is not cheap ($700), but I like to play with it and I use it often...
The SuperBuddy from Applied Instruments.
I bought this in order to align my WildBlue internet dish. It was really more of a toy for my hobby beyond that.
The best satellite meter by far would be a Coolsat 5000 receiver and a small LCD TV! You just cannot beat it. The price is right (especially nowadays) and it functions very well! Perfectly suited for satellite hunting and programmable by you!
RADAR
I've picked a satellite but how to know which is?
Can I run a dish motor with my DishNetwork 501 or 522?
