Losing Sound on 922 | SatelliteGuys.US
Losing Sound on 922
brinack
17
Wisconsin
When fast forwarding or just watching shows does anyone else lose the sound?????
Sometimes it can be fixed by turning it off and on, other times it takes a reset to fix it.
Just started happening not to long ago...........bad update maybe?? Just wondering if anyone else is having this issue.
Yep, I've had it happen to, sound gone from one 'tuner' whether it's being viewed over hdmi or the distributed co-ax. For me, the only way to get it back is to reset the receiver.
Found a way to get it back. Just keep hitting the skip back button until you reach a part of the recording where the sound comes back. Then you can skip forward and it works.
Strange but seems to be a issue once in awhile with the skip ahead. At least I dont have to reset everytime anymore.
VIP 211 remote?
Broken 3222: Do I need the service plan?
