navy, I took your post to mean that it does work if you have the CUI.
That's how I took it too.
If you highlight the icon, the title scrolls so you can read it.If the name is long, how many characters show under the icon before it gets cut off? On the ViP list view, it's about 20-25, depending on character width.
Reliable? No receiver I've ever owned, including the venerable ViP622, has been reliable until at least a year's worth of software updates.Us ViP guys just are too optimistic. Comes with the territory of dealing with reliable receivers, I guess.
Well, I'm on year 6 of my 722. Still going strong, from the very beginning. KOWReliable? No receiver I've ever owned, including the venerable ViP622, has been reliable until at least a year's worth of software updates.
You got lucky.Well, I'm on year 6 of my 722. Still going strong, from the very beginning. KOW
Never needed one on any Tivo, HR, SA, Motorola receiver.
I shouldn't have to buy a cooling fan for a receiver.
Period...
My receivers are placed at room temperature not enclosed.
If a receiver can't operate properly in a 68-74 degree environment without over heating well thats a poor design.
Dish supply you with the cooling equipment?
Sometimes you don't have the luxury of having a DVR is the open for air flow or having cabinet in a slide with thinner walls so a fan to assist the cooling of the DVR.
For the luxury folks, you would bitch about the fan noise if a fan were built in.
He just has to be contrary. But I've learned to answer maybe once and then move on.Troch, right on cue!![]()
I have to agree with him from a technical standpoint. If the receiver doesn't function properly but adding, for example, auxiliary cooling, allows it to work properly, that's wrong. Does it mean it's poor design ? Not necessarily.... It could be that the receiver is located in the wrong location (the manual says not to put it in a closed space). The environment could be excessively dirty (dust, hair, etc) that gets sucked into the receiver impacting it's cooling design.A Dish DVR has no excuse to over heat under normal conditions unless its defective or poor design.
Limited time offer
