Lost manual pid entry on my Manhattan | SatelliteGuys.US
Pixl
Senior Member
1,902
67
Traverse City, Michigan
I've either lost my mind, or my pids.
I've connected the Manhattan directly to a motorized Ku dish so I can start using it without switch support. I went to use the manual pid input for the first time, can't find it now. Was there a few weeks ago, I've done no FW changes.
Tp list
find the TP you want to enter the pids
press select (or OK)
top line (I'm not near mine) change to advanced or PID maybe
enter pids
scan TP
Tp list
enter pids
scan TP
Ok Ice, I found it now. Thanks, you got me in the right area.
If I may edit your instructions for anyone else reading this.
Highlight the top line (scan mode), arrow right change from normal to PID.
enter pids
scan TP
Ok, thanks. You got me in the right area and I found it.
I was trying for KFTL on 72w 11967 H 1666.
I can lock the TP, but can not scan in and manualy entering the pids doesn't work.
The channel is up because I can get it on my OpenBox S-9 even though it is connected to a smaller dish.
I tried the manual entry this morning, pids went in, exiting out to the channel list there it was. It works!
Too bad Harold off, but I like to watch Diane Bish and they have her up a lot now.
Hi Jim, I just saw this post and happened to be blindscanning AMC6, testing out a Digiwave 8x1 switch, which is new to me. I scanned in the 11967 H 1666 just fine, of course it's on a 1M dish, so that will make a difference.
Regards :)
Brent,
I'm on a 1.2m Ku dish, got tons of signal once it locked, getting the low SR to lock was challenging my Manhattan. My OpenBox scanned it right in even though it is on a smaller dish.
Are you switching that Digiwave with your Manhattan or your Solomend.
Brent,
Switching the Digiwave with the Manhattan box.
What is the best RG6 compression tool available on the market?
RG6 COAX CABLE
