lost voom | SatelliteGuys.US
lost voom
rodder
2,351
105
Adairsville,Ga 30103
just had voom installed sat was just watching lost everything the reciver still has power but i am geting nothing! :confused:
Is the satellite icon green or red?
Is the menu still working?
Check the signal quality readings: HELP-INFO-OK-Down-Down...
Yeah, if there is no menu, it's either a lockup, in which case you need to reboot, or you accidently switched the input on your TV set (e.g. by pressing the INPUT button on VOOM's remote). Most likely a lockup, since the icon is red.
Give it a minute, then press VOOM button. Do you get a menu?
Check all connections to the box and the TV set.
Ok, when you rebooted, was the TV screen blinking at all?
Can you verify that your TV is set to the right input? Does it work at all?
Is the icon on the STB still red?
Try unplugging the STB for 20-30 seconds. After you plug it back in watch what happens on the STB's front panel. See if the horizontal lines on the right side will start blinking in sequence. Which one will be the last to blink?
VOOM HD? Really dont think so
Does my Voom box have a coaxial digital output?
