LoveWorld added to Glorystar | SatelliteGuys.US
Thanks Iceberg! IA5 is one satellite I was warned about blindscanning with my Fortec receiver (causes corruption and have to reset the receiver). Is there somewhere all the channels for Glorystar are listed (with frequency, polarity, and symbol rate), so I wouldn't have to do a blindscan to find all of them? I am very interested in seeing what develops with Glorystar!
The main transponders Glorystar has channels on are
AMC4
11822 H 5700
11860 H 28138
11983 H 5900
12020 H 2034
12120 V 30000
IA6/G25
11836 V 20770
11874 H 22000
11966 H 22000
11999 H 20000
12122 H 20000
12177 V 23000
Wow, very helpful as always! Thanks so much Iceberg! Yes, I had seen the "updated channels" list on their website (with the detailed info I needed), but was looking for the "complete list", however with the list of transponders you listed here I will now be able to find all existing channels, and will count on the "updated channels" list to show me any new transponders which were not listed before (or watch for updates from you like this one!).
Thanks again!!!!!!!
no problem :)
The AMC4 list is correct and the IA5 one I think is correct. I checked the Glorystar site and they didnt list a complete list but hopefully the above is what will work :)
I have had problems with that and my Fortec as well....if you blind scan allot you end up with allot of duplicate & triplicate channels for some reason (I do anyway).
Glorystar Aiming Calculator / Site Check Tool
Guide data?
