Luken channels on 87 c band | SatelliteGuys.US
fta4life
32
Beaumont,Texas
I am tuned in pretty well so far on my 9 footer but i notice quite a bit of s2 signals are showing 10 pct quality like the 87 luken mix and i am not scanning them in while most regular stuff is in the 70's on my microhd.
Any of you have problems locking the luken channel mix?
The Luken mux is hard to pull in but should not be a problem with a 9ft dish. With a little tweaking you should get them just fine. I get them for about 1/2 to 3/4 of the day usually with a 6ft dish and am watching heartland as I type. I've noticed that it does seem that my reception is better on colder days.
If you are getting quality, then half the battle is won. Ive found that its hard to peak your dish using the stronger transponders. Use the weaker ones to tune. Small adjustments make a BIIIIG difference.
My quick 30W Frankendish
Hooking up motorized ku dish and c band dish on same reciever
