Mac OS X 10.8 Mountain Lion | Page 3 | SatelliteGuys.US
BTW,my problem with closing the tabs on Safari 5.2? The "x" all of a sudden showed up on the tabs to close. The only thing that I can figure that caused that to happen is that I'd originally had my Safari set to open in 32 bit mode. Now I have it running in 64 bit mode by unchecking the box for "Open in 32-bit" in Get Info.
Does Safari 5.2 beta have the unified search bar? i.e., like Chrome, where you can type in a search or a url?
Rocky, I've never seen the spinning blue circle (except on Windows 7). Are you running Parallels or some other emulator?
My Lion on my MacBook Air is 100% 64-bit Intel executables. If you want to check your Mac, bring up the Activity Monitor and look at the "Kind" column.
No emulators. I am running 64 bit, but some apps don't say it.
I am only seeing the blue circle on the Air, not on the pro (which is also on 10.7.3). Not a big deal, and indeed, in the past day or so, I have no seen any spinning circles at all. :)
Trivia tidbit:
Got my new Apple battery in and decided to take the original apart to see if the cells are bad or something else. Cells are good but what I discovered was interesting. The batteries are made by Sony. :) Seems the circuit board is bad.
