Menu, Installation, Satellite Installation.
From there you can pick your satellite if it is not already chosen.
WHILE IN THE SAME MENU SETTING:
If you need to add the transponder hit the
yellow key on the remote. This is transponder edit. If you look to the right side on the screen you seen the colors that do what.
While in transponder edit, you can
add a transponder if needed, by pressing the green remote button that corresponds to
ADD. If the transponder already exits, while you have that transponder selected you can press the
white key on the remote to add a
user channel. From there you can enter the information if you have it. You must know the PID info etc.
Hope this helps.
