Manual timer end time cannot be later then 11:59 pm on Hopper 3 | SatelliteGuys.US
vlogical1
22
16
Atlanta GA
The manual timer (create a timer) on the Hopper 3 will not allow an end time of later then 11:59 pm. For example is not currently possible to set a manual timer from 9 pm to 2 am. There have been several software updates since the Hopper 3 first came out but this has not been fixed yet as of the latest software of U313. The option to set a manual recording that has an end time of later then 11:59 pm is available on the HWS.
Could Scott or someone from Dish please report this issue to Dish. This is an important functionality that was previously present but was removed from the Hopper 3. As recently Scott opened a thread regarding OTA recording problems and I think this issue should also be addressed by Dish.
Also if for some reason there is a problem for Dish programmers to allow for a manual timer to begin on one day and finish on the next they could always allow the user to set a start time for a timer and then instead of having an end time have a length of recording instead of an end time. This is how Direct TV does the manual timer.
Speaking of manual timers (or "create a timer") we have to select a particular channel which creates "seek" instead of DVR. I noticed that when I recorded a ball game last week, I was asked if I wanted to "record all future games". I said "yes" and I noticed that the "seek" timer the system created was for "all channels". There doesn't seem to be a way to do that manually - or am I just missing it? That would really help cut down on multiple timers for the same program on different channels.
You would think they could do that. As a work around can you set it to 11:59 then go back and extend the manual timer 90 minutes? (Of course you could do a second timer, again not ideal)
I already tried, but unfortunately you can not extend and add time to the end of manual timers the way you can to timers set thru the guide.
Reactions: dare2be
VIP222 with MT2 OTA module = complete signal loss
Hybrid LNB Question
