I have had a Maxtor Personal Storage 3200 drive that I have been using since EHD support was added.
I leave it running all of the time and have had no problems up until now. The last time I accessed it was prolly a week and a half ago.
Now, when I go to access it, my 622 is saying there is no usb device attached.
I have unhooked it, re-hooked it. Shut everything down with it unhooked. Hard-booted the DVR and let it come all of the way up then tried re-attaching the EHD. It will not recognize it.
One time, and one time only, when I unhooked it, I did get a message that the usb device had been disconnected. That is the only message I ever got when hooking or unhooking.
The drive spins up and is spinning. That is evident from holding it.
622 is running L614 software and the only thing that has happened that comes to mind since I last used it is installing the new smartcard.
I know I can't hook it to winblows to see if there is a file structure there, will a linux boot CD let me browse the USB drive to see if there is still a file structure intact? Man I am going to be pissed if my sh*t is gone.
And I have run HD's for years. I know shutting them down and re-booting is worse than letting them run.
As a matter of fact, the PC I am typing on is using an 8 year old (at least) 40 gig HD as the secondary drive. Along with the other 2 drives in the machine. I keep moving them as I upgrade and set power setting to not spin down the drives. And I leave the machine running 24/7.
