Pictures not bad for SD, least Hawaii 5-0 but do see the skinny look using standard SD format. So its meant to be watched in stretch I'm guessing. Not happening, just another channel to add into the abyss of unwatched channels.
A horse is a horse of course......![]()
Now Wiiillllbbbbeeeerrrr!![]()
If you stretch it the format becomes correct.
MeTV is not available in all areas on DISH if you already have a Local METV channel on DISH then you won't get the METV channel 247
What they heck? I saw no issue with the Wild Wild West show that ended a half hour ago. The aspect ratio looked correct and everybody looked normal.
I have a local METV, I do not sub to sat locals, and yet 247 is there for me.
BaloneyMeTV is not available in all areas on DISH if you already have a Local METV channel on DISH then you won't get the METV channel 247 go to metv.com where to watch page Where to Watch MeTV type in your zip code to see if you have METV on 247 on DISH
I have both. Dish version is 3 hours earlier too.MeTV is not available in all areas on DISH if you already have a Local METV channel on DISH then you won't get the METV channel 247 go to metv.com where to watch page Where to Watch MeTV type in your zip code to see if you have METV on 247 on DISH
Ok, I get it now. Mine is OTA not from Dish. Channel 008-02.Looking at the DISH chart they don't show that they provide METV as part of your locals. Do you mean you get it over the air? Over the air has no bearing, but it is being reported if METV is an actual channel DISH already provided as part of your local package you would not get channel 247.
I thought METV was one of the subchannels that was not able to have a national channel on satellite due to restrictions about locals or something?
Limited time offer
