Mitsubishi WS-55511 Screen Question | SatelliteGuys.US
Kurkus
12
Lansing, Michigan
I have a 55" WS-55511 Mitsubishi TV and now have a small crack on the outside screen
Is this screen Glass or Plastic? is the screen just a glare screen?
How do I know if I have a diamond Screen or plain plastic screen
Can I remove the screen and watch the TV without the outside scren?
Can I order a replacement screen and where would I get one least expensively
thanks for any help anyone can offer
The last discussions concerning this model was years ago so I put this here
I believe it has the plain plastic screen. You might try calling an authorized service rep in your area. It might be hard to get hold of being six years old.
S~
S~
It does look like it's plain plastic with another screen (diamond maybe?) about an inch behind this one
I wonder if the plastic one can be just removed and left off
I have the Service Manual for the WS-ssm13 series, but I'm not sure if it would help you much as Mitsubishi can't even come up with a standard set of screen disassemblely instructions even within the same model year. You can try Googling your model number and "Service Manual" and see if you can score a PDF of your manual.
Also, the Home Theater Spot has a lot of Mitsubishi RPTV owners and has been a good source of information for me.
I just replaced my WS-55511 about 4 months ago (lightning strike). The front screen is plexiglas to protect the diamond screen behind. It is removable and replaceable. If I recall you can remove the top trim piece around the plexiglas screen and lift the screen out the top. It's a shame you're not closer because I have that screen in my storage shed. Don't ask me why I saved it, but just couldn't see throwing it out.
thoughts on projection TV
Yamaha receiver AM antenna
