MoCA says Server & Internet Connection Failed but everything works!? | SatelliteGuys.US
winter60
22
27
Woodbury, MN USA
I have a Hopper 3 with a Joey 3 connected to it via MoCA. Everything seems to be working fine but I all of a sudden am now getting a little icon in the lower left corner of the screen on the Hopper saying "MoCA".
When I check the Internet Settings under Network Status, MoCA shows red Server Connection Failed and red Internet Connection Failed. DHCP is green OK and all of the other information looks normal.
Everything seems to be working fine. I can use the Joey and all channels work, including streaming channels. When I call up Network Details on the Joey, everything is green and it shows everything connected. It is the Hopper that has the red errors.
Any ideas what is going on. I used to get a message under MoCA that said "Strong" for connection status.
I restarted both the Hopper & Joey and reset my Router. Still same issue.
I will add that the cable run between my Hopper 3 and Joey 3 is dedicated RG6 Quad Shield. No splitters or anything else in the patch, except of course the solo hub.
Thanks in advance for any replies.
