Hi all - I have installed many fixed small dish systems but am having absolutely no luck with this first motor install
My system: Fortec Classic NA, 100 cm dish, HH100 Motor, Invacom quad with diseqc 2 way switch. L on 2, C on 1. Used 11250 for c and 10750 for L.
Installed at zip 48108 using 42.13N 83.43W. Perfectly level mount. Checked and re-checked.
Dish elevation set at 23.5, Motor elevation set at 42.
180 degrees + 6 = 186 used for true south.
I followed the HH-mount-installation.htm at sadoun's site carefully and rechecked several times - what might I be doing wrong?
I have worked several times to get a signal on a true south bird using (at different times, of course): AMC3 @ 87W, Nimiq2@82W and AMC5 @ 79W and have never been able to get any signal reading.
Knowing that I may be missing something completely (there are trees, but very far away), I setup an old 18" dish and was able to get 24% right off and 80% with a little wiggling.
I hope I have given enough info - let me know what other variables might be needed to troubleshoot.
I have read and read and read and tried to start from scratch 3 or 4 times, so Im really open for any suggestions.
Any help would be greatly appreciated
BPR
BPR
