fv3 said:I have the impression that the UberDish will actually be manufactured as either a 105 or a 121. So you will get either one or the other and it will not be switchable. (Note the spacing between 110 and 105 is different than the spacing between 119 and 121....)
Stargazer said:The SuperDish they showed on the last Charlie Chat did not have the lnbf's look the same as it does in those Team Summit pictures on Dishretailer.com website. It looked like it had a twin lnbf and a single lnbf next to it seperate, not all in one piece.....
Tim Hanthorn said:Stay tuned...more info on SuperDISH was promised at the Baltimore Team Summit later this week. I believe, however that the twin would remain pointed at 110 and 119 with the ku-FSS LNB on one side to point at 105 (a little farther east) or on the other side to point at 121 (a little farther west). Ultimately, there could be two ku-FSS LNBs (one on each side of the twin) to get a look at all 4 satellites.
The way the geometry works on the dish 500 the LNB to the east looks at the satellite to the west (119) - the signals reflect off the dish across to the opposite side. I would expect SuperDISH to work the same.
I'm sure the gurus will have some answers for us in a few days.
Stargazer said:You have easier access to the dish when it is on the ground vs. the roof. It would suck to have to go on the roof to get the ice and snow off your dish in the winter or to repair it if needed.
Stargazer said:....Couldn't they make the adapter slot for 105 allow that lnbf to point more towards its focal point a certain direction rather than being spaced closer to the 110 lnbf?
Stargazer said:... even though the dish itself will be made of plastic/fiberglass.
gpflepsen said:Stargazer said:... even though the dish itself will be made of plastic/fiberglass.
Really? The superdish won't be steel like all the previous dishes?
Limited time offer
