Put all of the equipment inside, only one hole needed then.i would be drilling 2 less holes if i put it after the splitter... correct?
Sounds like either a bad connector somewhere, or the dish is out of alignment.help!!!! i tried to install this today. i believe i hooked everything up correct. but on sat signal screen only about every 5th one is at 96 while the rest are at zero. what have i done wrong?
every thing is working fine now. nothing i ordered came in bad. he did replace the dish though. i am getting all 95s or 100sThe only satellite you could get that would show up on Directv receivers is one of Directv's.
I'll bet the signal is going in and out and that's why you're seeing that even pattern of 0s. Go to the signal meters screen and pick one of the transponders showing non-zero and watch it for a while and I'll bet it flips between 0 and non zero. Which would most likely indicate a bad LNB.
Limited time offer
