MRV Gone? | SatelliteGuys.US
MRV Gone?
Mark0525
113
Ohio
I've been using the MRV on my 2 DVR's, 1 - HR23 and 1 - HR22. Worked pretty well. Last night I went to my bedroom to watch a show and there was no networked DVR's shown. I went down to the one in the family room and same thing. I did a reset through the menu on both machines and still nothing. I checked and I still had the static IP addresses and I did all the network test and everything checked out fine. I was able to connect through the internet fine. Any ideas what happened? I'm wired in and everything has lights on as far as going through my switch to my router to my modem.
you're wired in every room or are you using powerline adapters?
I'm wired in every room that I need to be wired. But the other rooms don't have the update yet. They are H23's. The 2 that I'm talking about are DVR's that have been working for about a week now nothing.
Did you look in the setup menu to see if MRV was inabled on both units?
Yes they were. I went home at lunch and opt out and then opt back in and rebooted and everything is fine. Thanks for your help
H21/H23 Audio/Video Sync Problems on Locals. Directv Aware
D* install at boat dock
