Multi TV's w/Direct | SatelliteGuys.US
Multi TV's w/Direct
Jaybird28
47
Seattle
Here's my delemia--
I will have a DirectTV Receiver on the Bedroom TV. Currently my wife runs a cable (Comcast) to a little tv in her bathroom just so she can watch TV briefly while she gets ready for work. Is it possible to run a cable to this little TV with DirectTV and have the main bedroom TV/receiver obviously be the channel selector???
I think you misinterpreted his question. He wants to know if he can split off the main receiver to feed the bathroom. The answer then is yes. You can take the RF output (or split it if it's already used) and run it to that TV. Then you have to change the channel in the bedroom, unless you get a remote extender, in which case she could use the remote in the bathroom.
Thanks Andrewwski-
Your correct. She can walk around the corner to change the channel. When you say RF outlet, is that the usual cale outlet that comes from a TV for normal cable?
Kansas/Aggies Bad Breakup on Espn HD?
Got a download "upgrade"... HD-DVR erased
